My unit went nuts on me. It went into Spanish language. When I want to go into SET-UP, I notice that the screen is split in 2. I disconnected the unit for 12 hours and turned the unit back on, hoping it would reset itself or at least let me start over and reprogram the unit. When the unit was new, the first thing it did was give you the option of setting the language, but it doesn't do that.
You will likely need to navigate through the menu again to change it back to english. The manual usually has screenshots of the different menu options making this fairly easy.
Google is your Friend -
I know on initial startup you can navigate to the different languages, at least when it was working properly, but it doesn't allow that now. Anyhow it is very difficult to see the setup because the screen is now split in two. Also the front panel is dark, but I guess thats due to fact that the time needs to be set, but again, its difficult to make out because of the screen being split. I am wondering what this will cost to repair.
Panasonic DMR-EH55-Recording HD channels in full screen (16 x9)
By Marshfish in forum DVD & Blu-ray RecordersReplies: 6Last Post: 28th Dec 2009, 22:05 -
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 20:57 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 20:45 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 17:15 -
Question about Dubbing on the DMR-ES40V
By kbRenePerez in forum DVD & Blu-ray RecordersReplies: 16Last Post: 18th Nov 2007, 14:28
