Hi,
Just quick question, will a "DIVX file with menu" playable on a DVD player tthat support DIVX playback? Will the file play without Menu or will it not play at all?
thanks
It must be a divx ultra certified dvd player, http://www.divx.com/products/hw/browse.php?c=16 , and it must be authored with divx authoring tool like divx author, tmpgenc dvd author 3, divxmediabuilder.
Yeh i know it require divx ultra certified dvd player to play the file with menu. But I ask IF the player Is Not divx ultra certified dvd player, will the file play without menu or will it not play anything at all?
thanks
EDIT: nvm, I'll just open the .divx in virtualdub and save as .avi and it would get rid of the menu and properly playable on normal dvd-divx player. -
Ooops...Yes, an ordinary divx certified player should play .divx files but not the menu then.
Assuming the .divx file respects all the other restrictions (resolution, bitrate, Qpel etc.) then yes, a certified player will play it. A non-certified, generic mpeg-4 capable player might not recognise the .divx extension, but should play the same file if it is either remuxed into an avi container, or has the extension changed to .avi
Read my blog here.
Based on my limited experience with Philips DVD players that support Divx but are not Divx ultra certified, they will play such files fine without menus, BUT you will probably have to rename them from *.divx to *.avi for it to work. Some players may not understand the .divx file extension.Originally Posted by psxiso
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 09:32 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25 -
Standalone Player plays only 33 mins of the resulting DivX DVD
By penguin74 in forum DVD RippingReplies: 8Last Post: 30th Oct 2007, 18:25
