I have a Daytek DVR-950S and I need to upgrade the firmware. Unfortunately, this will cause the formating of the HDD. Instead of burning all of that video to DVD, I pulled the drive out and put it into a USB case. The computer sees the HDD and the files on it, but when I try to play a file, it won't play. I can't open the files in Video Inspector to get any info on the files. I also tried to open the files in MPEG-VCR, without luck. Is there any way to rip these files to the computer?
Thanks,
Ted
I don't know what to tell you.
You can likely move the files as a data block to one of your computer hard drives, but that won't help you any to open them.
I would take the easy way out. Put the drive back in the DVR and burn the files from there, then reformat the drive with the upgrade. But you may have already figured this out.
But another member may have a better solution.
And welcome to our forums.
What is the file extension of the files? You likely won't be able to just play the files. At the least, I would expect you would have to convert the files to a standard pc format.
Google is your Friend
Problems with ISO file backup from HDD to HDD
By badboytim999 in forum Newbie / General discussionsReplies: 7Last Post: 15th Dec 2011, 09:03 -
Reading HDD from HDD recorder on Windows XP
By mvidelgauz in forum Newbie / General discussionsReplies: 12Last Post: 18th Apr 2011, 03:51 -
Problems reading .mts files (possibly corrupted)
By moxiecat in forum Video ConversionReplies: 24Last Post: 7th Mar 2011, 14:35 -
recover *.mts files from external HDD ..tried restoring hdd software
By ravistudios in forum RestorationReplies: 0Last Post: 18th Mar 2010, 13:24 -
LG HDD Problems with vts files on PC
By eScenCe in forum Newbie / General discussionsReplies: 2Last Post: 7th Apr 2009, 14:08
