    Aug 2001
    I can capture real time TV video (and sometime audio) using my Canopus ADVC110 connected through my VCR. I would like to view the video in real time as well (ie. watch tv) on my PC. Capturing software only typically has a small preview window.
    Is there software that will show a full screen of real time captured video?
    There should be, but can't find it.
    Thanks in advance
    Aug 2007
    I use Ulead Video Capture which is part of MediaStudio Pro. It lets you set the preview to full screen (user defined). The only problem is that there are interlaced lines, but it is not that noticeable if you sit at a distance. It does have audio as well.
    It is expensive. Ulead offers a trial version if you want to try it.
