  1. Is it possible to create an MPG using TMPGEnc? I can't see any option other than to create an m2v and a wav, which I then have to turn into an MPG anyway, so it'd be nice to remove a couple of days from the process.
    Yes, but you must choose to use mpeg1 layer 2 audio and not wav/pcm. If you use wizard it should be in the first steps.
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Then again - If you're on to authoring a DVD, most authoring apps should accept (in fact prefer!) elementary streams...
    /Mats
  4. Under "Stream Type" select "System (Video+Audio)"
