I am looking for some advice on a capture device that will capture old VHS and 8mm camcorder tapes. Any suggestions? I have looked at the Canopus ADVC - 55 analog to digital converter,but it is a little pricey? Is there something else out there that preforms the same? I like the video/audio lock feature on the canopus, but again, it is a little pricey. Looking for good performance at a inexpensive price....any suggestions are greatly appreciated![]()
Please help me decide before the tapes go bad....LOL![]()
Results 1 to 12 of 12
DAC-200 FireWire Digital/Analog Video Capture-Converter
http://www.synchrotech.com/product-1394/analog-dv-converter_01-dac-200-firewire.html -
maybe transfer to DVDR via a settop burner? relatively inexpensive these days. also no mental exercise required...plug in, put in blank, turn on TV, set duration (quality) of burned disc, start. -
I think there was an ADS Pyro that goes for around $50...
these devices export in DV -
I have an older Sony analog camcorder, and just got finished capturing a couple of dozen analog tapes into mpeg2, then used Pinnacle Studio 10+ to edit and burn to DVD. I used the Hauppauge 250PVR card, and it worked flawlessly. I will say that Pinnacle can be a pain, so I am not necessarily recommending it for authoring. I figured out how to make it work well, but I can't guarantee that for all computers.
The understatement of the century, I think. Saying "Pinnacle can be a pain" is kinda like saying "the surface of the sun is a bit warm."Originally Posted by ranchhand
Don't sweat the petty things, just pet the sweaty things. -
I have used a Pinnacle 9 USB Moviebox to capture VHS tape video and audio. You don't have to use Pinnacle to edit or burn anything, but the Moviebox has done a good job for me as far as capturing is concerned. It gets saved to your hard drive as an MPG, so you can use anything to transcode and/or burn it.
The Pinnacle Moviebox probably costs $100-$150 or so these days. -
I really appreciate the feed back, but I am stilling wondering if I should just buy the Canopus ADVC - 55? Is it worth the cost? Is a firewire output better than USB 2.0 output for Video capturing/converting (analog to digital)?
I would strongly recommend the Hauppauge WinTV PVR USB2 for your purpose. Alternatively a standalone DVD/HDD recorder.
Why would you strongly recommend the Hauppauge WinTV PVR USB2? What have you experienced with this device? Also, does it have a problem converting PAL or NTSC? And, thank you for your suggestion. I am looking at the specifications now...Again, thanks
I would be careful of USB2 capture devices. I have an Adaptec and it uses proprietary drivers that prevent the use of most commonly available software. About the only program it will work with is Sonic MyDVD.
8mm capture camcorder dilemma
By TopazUK in forum Capturing and VCRReplies: 4Last Post: 5th Mar 2012, 02:42 -
8mm camcorder capture/transfer
By ViewCam88 in forum Capturing and VCRReplies: 0Last Post: 9th Jan 2011, 22:19 -
Best outboard consumer capture device today? VHS, LD, camcorder and HD DVR
By cosmichippo in forum Capturing and VCRReplies: 4Last Post: 11th May 2010, 13:46 -
Capture device needed ...PLEASE!!!!! HELP!!!
By Bertomotology in forum Capturing and VCRReplies: 20Last Post: 4th Dec 2009, 15:29 -
Should I get a new camcorder or an external capture device?
By steppenwolf_27 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 9th Jul 2007, 14:36
