I had my wedding taped on my camcorder and it totalled about 82 minutes, but it's 17 GB. I want to burn this onto a 4.7GB dvd, but since it is something so important, I don't want to reduce the quality down to crap. It is an AVI file, and I'm not sure what different formats can be used in a normal dvd player. I've seen some forums say to make it a wav file, but I don't know what that would do quality-wise. Please help me out here. I would appreciate any suggestions.
	It is DV avi. If you encode it carefully to DVD using 2-pass VBR encoding, with audio at 224 kbps AC3, you will fit it on a single layer DVD. If you use a dual layer DVD then you can use CBR encoding at 9400 kbps and 384 kbps AC3 audio. You should be able to retain all the quality doing this. Read my blog here.
	If you do it as recommended, 82 minutes will get you a decent DVD on a single layer disk.
 Just keep the original tape, it may outlive the DVD.
	In addition to the above good suggestions, I would also use Virtualdub in DirectStreamCopy mode to save as "Segmented AVI" using 4.25GB per segment, then make a checksum file (MD5, PAR, etc) to go with each onto 4 DVDRs as data backups. Then you'll have the "master" saved to 2 different types of media--much safer that way.
	Thanks for the ideas, unfortunately, I'm not sure what most of that means. Is there a program that I can use to make the file fit? Also, I think I may have a dual layer dvd burner. Is there a way I can check that? But as far as encoding and that stuff, I don't know how to do that. I saw something about dvd shrink on a different forum, but I don't know if that would apply to this. These suggestions would still maintain the quality, right? Thanks
	if you want to do away with using a computer to play around with this video buy a settop DVDR recorder, put in a quality blank, select the 2-hour mode, and burn a copy onto DVD in real time. No fuss, no muss.
 now you will have a clean way of transferring your future video captures into DVDs. if your captured video is less than 60 minutes then choose the 1-hour mode for the highest possible quality from your camcorder transfer.
 Bon chance.
  How to make an AVI better quality (keeping output still as AVI)?By Dogpoundz in forum Video ConversionReplies: 15Last Post: 22nd Sep 2011, 01:12
  DVD file too large to burn to disc..how can I make it fit?By Natalie88 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2010, 09:14
  How to Fit 3 movies on 1 DVD 4.7GB and keeping high resoultion and quality?By Virius in forum Authoring (DVD)Replies: 4Last Post: 8th Aug 2009, 16:12
  [Help] avi to wma keeping avi quality?By Riddick51PB in forum Video ConversionReplies: 4Last Post: 26th Jun 2007, 19:13
  converting .avi (divx) to dvd and keeping original quality...By RushMaster in forum Authoring (DVD)Replies: 15Last Post: 22nd May 2007, 15:47
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
