I am a tinkering person...so my machine is always changing. Is SVCD2DVD tied to your machine only? I notice it needs to access internet. Can I reinstall for ME ONLY on any machine or when I change stuff or reinstall XP?
Just need to know what my limitations are.
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
It goes as follows:
You do not need internet access from the machine you are registering. It just makes it easier. It can be done manually, via email - and that can be from another PC.
Currently you get 3 "machine licences". Therefore you can install on more than one PC. Once a licence is 60 days old you get another one (up to a max of 3).... So, if you are talking about a single PC: you can reinstall your operating system 3 times in 60 days and you will be ok. If you tinker beyond this - just drop me an email and I will reset your license count.
In addition to this, if you reinstall or upgrade to a newer build: your existing license will be reused as long as your PC has the same operating system as it did before. Thus, in theory, you can install on 3 PCs simultaneously and keep them all up to date with the latest build.
Bottom line - if it is for sole use, there is no issue.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I mess with my machine about 3 times a YEAR....so I am ok. Thanks for the info. I could not find it on your web page....maybe you should put it on there up front.
If it already is my apologies.'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
New PC/Registration
By sopwithpup in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 31st Aug 2010, 06:13 -
Registration
By guidorobben in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 17th Jun 2010, 15:17 -
registration
By ki46ej03 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Jun 2010, 06:20 -
registration
By ki46ej03 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Nov 2009, 04:10 -
registration problem
By wazzabee in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 12th Apr 2008, 15:50
