I have a DVDR which a friend gave me to check out since he could not get it to play. It played on my DVD player (it said bad disc a couple times and took a couple reloads before it played) but when I put it in my computer, no ripping program can read it and Windows Explorer says its an empty CD-R while Isobuster says its a blank DVDR but there certainly is material on it. Another post suggested downloading an update for the UDF reading dll (I have no idea what that is but I did it) and the computer still does not see the disc.
Is this a bad burn or was it written in some weird way?
Results 1 to 14 of 14
Bad media. Try on more computers, some dvd reader out there may read it. You can also try cdroller and dvdfab decrypter if you haven't done that already.
Neither DVDFabDecrypter nor CD Roller recognize that there is a disc in the drive. If it is bad media, then Datawrite certainly does not live up to the hyperbole on its website.
But how is it that a hardware player will read it but not a computer drive? -
this is where y finalise suggestion came from,,how did you friend create the dvd?,,isbuster should read it though, have you a dvd player and seperate dvd recorder, hitch the player up to the recorder and just copy it but make sure you finalise the new disc.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
He didn't create the DVD. It was a trade. I guess I'll have to look into DVD recorders.
does windows say there is a disc there
Try rebooting your pc with the disc in it
As far as ISOPuzzle is concerned, the disc is empty. It says UNNAMED_VOLUME (0 MB).
Just a suggestion but perhaps the disc isn't finalized. If you have nero (and yes this is the only time I will suggest nero) try to finalize the disc with it. I had a disc I once forgot to finalize. It would sometimes play on my standalone player. Could not read it from pc-dvdrom. Only drive that would read it was the burner I used to create it. Finalized it with nero and problems went away.
Edit... Just re-read your post and noticed that you couldnt read it in any drives so I guess my suggestion is moot. Sorry.Donadagohvi (Cherokee for "Until we meet again") -
This is an "oh screw it" situation, I always offer to sort the disc out for free if you'd mail it to me, or if you can play it on a dvd player and you know someone with a dvd recorder thats one idea, or if you can connect the dvd player to your computer and capture it.
Tool to batch download, save and rename QuickTime stream files
By oediv in forum Video Streaming DownloadingReplies: 8Last Post: 24th Dec 2011, 18:24 -
Need a Tool to read Pixel Aspect ratio of a file
By mlong30 in forum DVD RippingReplies: 4Last Post: 18th Oct 2010, 00:38 -
Can Real Player Downloader tool download any online videos?
By coody in forum Video Streaming DownloadingReplies: 5Last Post: 15th Mar 2010, 16:39 -
Can I use an upgrade key on Windows 7 with a Full version Download?
By terumaru in forum ComputerReplies: 5Last Post: 25th Oct 2009, 08:48 -
DVDR-3380 Firmware upgrade
By Spideray in forum DVD RippingReplies: 2Last Post: 25th Jan 2009, 03:13
