Hi all.
I use VCD2TK and tried to chapter an .mmd asset by entering timecodes. As I don't really know how to deal with timecodes, I loaded the file in VirtualDub and took its image number as reference. (at this point, I should ask for help about timecodes ;-))
But the numbers I took from VirtualDub are changed a bit in VCD2TK (the last 2 digits are changed). I suppose it is to align the chapter on an I frame. (as I loaded the mmd in VirutalDub trough an avisynth script, I only had 'K' frames)
Anyone can point me to a comprehensive timecode explanation? Is this the same as SMPTE? Is there any video player that shows the timecode while playing?
(Ah, we can't edit our post.)
Well, I've just ran a search in the forums and found a tool called "Entrypoint assist" on icidia.org, so I think I've got all I need to create chapters at VCD2TK's taste.
Thanks, and goodnite.
Timecode skipping
By rds11 in forum EditingReplies: 1Last Post: 23rd Dec 2010, 10:24 -
No Timecode on my tape
By towarmforacoat in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2010, 20:49 -
Burned in timecode - HOW?
By synaptic in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2009, 00:41 -
Converting drop frame timecode to non drop frame timecode, and vice versa
By picrade in forum ProgrammingReplies: 1Last Post: 1st Mar 2008, 05:22 -
timecode messed up
By snafubaby in forum EditingReplies: 4Last Post: 20th Sep 2007, 06:00
