Hi
I am having a Sony DVD Recorder RDR-HX720.First i was using a cable connection which i connected directly to the recorder and the aerial connection was given to the recorder and the TV.Then when i configured using the Easy Setup all the channels that were coming through the cable was available in the channel settings section.I was able to see the cable channels both in the TV and in AV1 using the recorder.
Right now i have bought a TATA SKY package which is a satellite tuner and the channels are coming in the AV1 and not in the TV.when i try to connect the satellite tuner to the recorder and then connect the recorder to the TV i am able to see the channels in the AV1 but when i try to configure using the Easy Setup there are no channels coming up.Because of this i wont be able to record any of the TV programs using the recorder.Let me know how to solve this issue.
Abdul
The recorder cannot decode the SAT signals, so the Easy Setup won't work as you have already found out. The TATA SKY box is used to decode your SAT signal and choose your channels. For recording, you would need to manually select the channel that you want on the TATA SKY box, choose the line in (whatever input the TATA SKY box is connected to), and then record.
Your only other choice, would be to get a DVR provided by your SAT provider (assuming they offer one). It will have the SAT decoder and recorder built into the same unit.Google is your Friend
TV tuner versus DVD recorder?
By Lupo in forum CapturingReplies: 3Last Post: 16th Aug 2009, 01:15 -
How to record satellite program on dvd recorder? Thru scart cabel or RGB?
By szalaikornel in forum DVD & Blu-ray RecordersReplies: 0Last Post: 22nd Jan 2009, 16:05 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 03:05 -
tuner in DVD recorder
By miki100 in forum Newbie / General discussionsReplies: 7Last Post: 4th Sep 2008, 00:18 -
DVD Recorder Tuner
By jh76 in forum DVD & Blu-ray RecordersReplies: 10Last Post: 7th May 2008, 14:24
