I tried converting an mp3 file to wma with Audacity, but my version seems not to do that. I then brought the file into Vegas 6.0 and tried to render it to wma for WMP9. I got a msg that no template was available. What's that about? I'm pretty sure I've used Vegas or some tool to convert the mp3 to wma. These seem to be the only two that might do it.
I am using Vegas 7, but I doubt much has changed for wma encoding. When I select wma as the output type, I get a list of templates ranging from 5 kbps up to 160 kbps. Why these are missing on your system is a mystery.
What happens if you press the Custom button and try to create a new template ?Read my blog here.
Oddly, it now works. Templates appear, and I am able to create a wma file. I think what might have happened is that a previous use of Vegas did not completely disappear when closed. When I tried bringing a new one up, my windows got frozen and I had to knock them down. All seems well now. The wma file works.
wma to mp3
By rjc7394 in forum AudioReplies: 5Last Post: 14th Sep 2010, 15:00 -
Movie's audio out of sync after converting WMA to MP3
By Talayero in forum AudioReplies: 11Last Post: 25th Sep 2009, 05:39 -
Help with MOD to mp3/wma
By Bluntz11 in forum AudioReplies: 10Last Post: 14th Apr 2009, 21:12 -
Is it possible to convert Mp3 to wma?
By t_jay17 in forum AudioReplies: 8Last Post: 17th Feb 2009, 17:32 -
wma to mp3
By rjc7394 in forum AudioReplies: 0Last Post: 8th Jul 2007, 20:28
