Hello Guys/Gals..
I want to start 2 project next year. and one of them is to convert some of the LaserDisc to DVD. The guide here is not working...
https://www.videohelp.com/guides?formatconversionselect=LD%20to%20DVD
http://geocities.com/mmelancholic/lddvd/guide_main.html
can someone help?
the other project is to convert the VHS to DVD! and i guess the guide above also helps!
so someone please help!!
What sort of help do you need ?
The basics are simple :
Plug the output of your display device (i.e. laserdisc player, VHS etc) in the inputs of a capture device (capture card, ADVC, DV camera with pass-through) to transfer the video to your PC.
Process the video if required.
Encode the video to DVD compliant mpeg-2 with compliant audio.
Author to DVD, with menus if desired.
Burn to disc.
Sit back and enjoy your work.
All of these steps are covered in detail by many guides in the Guides section (to your left) or the User Guides forum.Read my blog here.
Encode the video to DVD compliant mpeg-2 with compliant audio.>>
can explain a little more on this...
i got a capture card on my PC that i use to capture from my video cam. using virtualdub to collect the avi now.
i dun think ( although i have not check) that my 'older' vhs player has the proper output to connect to this capture card. ( i got to get that model number.... )
i get the basic idea that you are talking about... let me check what hardware i have that can be used. or that i need to purchase... -
Some cards have hardware assisted mpeg-2 encoding, which can be great if space is limited or if you don't need to do any post-processing. I find for VHS source material that I need to usually do some noise reduction and colour correction, so I capture to either DV (moderate size, easy to work with) or Lagarith (much larger, lossless compression). I then use avisynth to process the video.
If you are using virtualdub to capture them you probably aren't encoding to mpeg-2 as you go.
See the top left corner of this page for a section called What is DVD. This will tell you about compliant resolutions and bitrates. Most Mpeg-2 encoders have specific templates or settings for DVD encoding.Read my blog here.
Capturing from LaserDisc for DVD burning - best method?
By Xoanon in forum Capturing and VCRReplies: 11Last Post: 25th Apr 2012, 23:51 -
Laserdisc to DVD capture questions
By bmwracer in forum Capturing and VCRReplies: 3Last Post: 8th Mar 2010, 12:04 -
Current recommendations for Laserdisc conversion
By tonyaldr in forum Video ConversionReplies: 3Last Post: 19th Jan 2009, 10:06 -
Laserdisc: Blade Runner
By vhelp in forum Off topicReplies: 11Last Post: 2nd Aug 2008, 00:19 -
LaserDisc to DVD with TmpgEnc Xpress 4.0
By sapulidi in forum RestorationReplies: 5Last Post: 16th May 2007, 13:42
