I'm trying to convert my mkv files to divx so I can play them on my DVD player (divx capable).
The best tool I found so far is Dr. Divx if it could be a little bit stabler. In short, I don't need fancy features. All I need is just to convert mkv file to avi file with multiple auido track support.
I tried SUPER, River Past, AlltoAVI, etc. Those tools either too complicated (for me) or do not support more than two audio tracks.
Is there any tool as simple as Dr. Divx yet with multiple audio track support (at least 3 audio tracks)?
I don't know why. But Dr. Divx always throws "C: Inertion Error" on encoding. I tried different combinations: 2.0 stable + Divx 6.6.1. 2.0.1b4 + Divx 6.6.1. also tried Divx 6.7. no luck.
Same version of Dr.Divx works fine with MKV file enconded with AC3 audio. So I'm guessing it's having problem on decoding AAC?
But I can play the file with media player classic. I also tried to use realplayer codec instead of fddshow. no luck.
Any tips?
VCR replacement
By yuhr in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2011, 21:10 -
Looking for a replacement
By Peacedog in forum DVD & Blu-ray RecordersReplies: 7Last Post: 2nd May 2009, 18:13 -
Need a nero replacement :)
By a1i3n777 in forum ComputerReplies: 10Last Post: 4th Mar 2009, 01:20 -
Need a replacement for Divx Author 1.5
By Lothar1974 in forum EditingReplies: 1Last Post: 10th Feb 2009, 14:05 -
Pioneer DVR-433H Burner drive replacement - HDD Replacement 750GB succesful
By linkox in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2008, 11:57
