Thinking of buying this external dvd burner. LG SecurDisc 20x External Double-Layer DVD±RW/CD-RW Super Multi Drive Model: GSA-E60L.
My question is speed? AT what speed will I be recording if I use a usb port. Just curious about it. Can i record at at least 8X speed. Thanks all.
Thanks alot. Now I need to research if it's Vista 64 compatible. Thanks all.
The speed you actually record at will depend on the software you use, the speed of your system and the write startegy which the drive implements for a particular brand of media as well as the USB speed and the media quality.
USB 2.0 will allow speeds up to the full rated speed of the drive if no other bottleneck exists.
Ifr Vista64 supports USB interfaces and DVDwriters (which it does), this should work. Whether any bundled software does is another issue,
You should be more concerned with whether MSCE supports this drive and whether a firmware download for MSCE to use exists because LG drives are riplocked, and you need to use MSCE and the LG drive firmware file to remove the riplock. -
Thanks for the info. which External drives are NOT riplocked, in your opinion.
USB 2.0 sustained transfer tops out in the 25-32MB/s range so burn rates greater than 16x (22.1MB/s) can and do break real time. The burner software must pause.Originally Posted by oldandinthe way
External DVD writer to deal with CRCs
By ringo12 in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Nov 2009, 05:17 -
What's Better? DVD Writer or External Drive for DVR
By DerbyDad03 in forum Newbie / General discussionsReplies: 8Last Post: 16th Apr 2009, 18:01 -
External dvd-writer
By Pablo2k1 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th Jan 2009, 13:29 -
Best External DVD Writer
By poppy56 in forum DVD & Blu-ray WritersReplies: 6Last Post: 5th Feb 2008, 14:19 -
Anybody know how to change the speed of DVD Writer?
By mommyc in forum DVD & Blu-ray WritersReplies: 30Last Post: 25th Sep 2007, 15:58
