I don't know which is 'better', but I would lean toward the LG because at least you know who made the DVD burner inside the enclosure. The Memorex/Imation burner could be made by just about any burner manufacturer. But this is just my opinion as I don't have any experience with either unit.
Stand by, though. I'm sure someone here has used one of those units.
LG makes drives, Memorex does not. This means firmware updates willprobably be slower from Memorex.
The specific LG drive you have identifies is new I can't seem to find which chipset it uses. If it is one of their Rennassas chipset models it is likely to be a superior drive, less so if it is Matsushita (Panasonic).
PAL -> NTSC DVD Writers?
By tac7 in forum DVD & Blu-ray WritersReplies: 4Last Post: 2nd Aug 2010, 21:34 -
Sony and Optiarc DVD writers
By anfield7 in forum DVD & Blu-ray WritersReplies: 2Last Post: 1st Oct 2009, 22:44 -
Samsung DVD writers differences (SH-S223Q/BEBD vs SH-S223Q/BEBS)
By TheWolf1 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 11th Aug 2009, 15:34 -
XP does not recognize my DVD writers as DVD writers thinks they're CD write
By steve1040 in forum DVD & Blu-ray WritersReplies: 5Last Post: 25th Jul 2008, 01:52 -
Buying 2 SATA DVD Writers
By mis3 in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Aug 2007, 22:08
