I keep getting an error on some recordings when ripped into ISO mode that says that the disc image is 1 block too large to fit a +R blank. Weird thing is this doesn't happen with all discs. Aggravating to say the least. I have been doing some experimenting with other ripping programs and it seems to be unique to Decryptor. Maybe the program is just too old now but the recorder is also old. Clone DVD 2 on the other hand makes a perfect ISO that can be burned with IMGBurn just fine. Also weird thing is that if you proceed with the burn using the Decryptor ISO and let it error out, it will finalize the disc and it will play perfectly anyway. Here is the log:
I 10:27:30 Source File: G:\Ripped DVDs\**** + ****** **** *\DVD_VR.MDS
I 10:27:30 Source File Sectors: 2,295,105 (MODE1/2048) (*note* too big by 1 block!)
I 10:27:30 Source File Size: 4,700,375,040 bytes
I 10:27:30 Source File Volume Identifier: DVD_VR
I 10:27:30 Source File Application Identifier: LVW5001VR
I 10:27:30 Source File Implementation Identifier: LiteOnIT
I 10:27:30 Source File File System(s): ISO9660, UDF (1.02)
I 10:27:30 Destination Device: [0:0:0] HL-DT-ST DVD-RAM GSA-H22L 1.02 (D(ATA)
I 10:27:30 Destination Media Type: DVD+R (Disc ID: MCC-004-00) (Speeds: 4x, 8x, 12x, 16x, 18x)
I 10:27:30 Destination Media Sectors: 2,295,104 (*note* file size is 1 block too small!)
I 10:27:30 Write Mode: DVD
I 10:27:30 Write Type: DAO
I 10:27:30 Write Speed: 12x
I 10:27:30 Link Size: Auto
I 10:27:30 Test Mode: No
I 10:27:30 BURN-Proof: Enabled
I 10:27:30 Filling Buffer... (20 MB)
I 10:27:31 Writing LeadIn...
I 10:27:52 Writing Image...
W 10:33:18 Failed to Write Sector 2295104 - Logical Block Address out of Range
W 10:33:18 Retrying (1 of 20)...
W 10:33:18 Retry Failed - Logical Block Address out of Range
W 10:33:18 Retrying (2 of 20)...
W 10:33:18 Retrying (3 of 20)...
W 10:33:18 Retrying (4 of 20)...
W 10:33:18 Retrying (5 of 20)...
W 10:33:18 Retrying (6 of 20)...
W 10:33:18 Retrying (7 of 20)...
W 10:33:18 Retrying (8 of 20)...
W 10:33:18 Retrying (9 of 20)...
W 10:33:18 Retrying (10 of 20)...
W 10:33:18 Retrying (11 of 20)...
W 10:33:18 Retrying (12 of 20)...
W 10:33:18 Retrying (13 of 20)...
W 10:33:18 Retrying (14 of 20)...
W 10:33:18 Retrying (15 of 20)...
W 10:33:18 Retrying (16 of 20)...
W 10:33:18 Retrying (17 of 20)...
W 10:33:18 Retrying (18 of 20)...
W 10:33:18 Retrying (19 of 20)...
W 10:33:18 Retrying (20 of 20)...
E 10:33:22 Failed to Write Sector 2295104 - Logical Block Address out of Range
I 10:33:22 Synchronising Cache...
I 10:33:39 Closing Track...
I 10:33:40 Finalising Disc...
E 10:33:46 Failed to Write Image!
E 10:33:54 Operation Failed! - Duration: 00:06:16
I 10:33:54 Average Write Rate: 13,909 KB/s (10.0x) - Maximum Write Rate: 16,935 KB/s (12.2x)
No idea why Decryptor is making an ISO that is one block too large but I guess this is where we part company.
DVDDecrypter no longer faithfully reads discs from my OLD Philips DVDR985...but that is because my OLD DVDR985 is dying and no longer making very good discs.
It should have been put to bed long ago when it stopped being updated. There are other current tools available.
Google is your Friend -
Hi,
In tandem with AnyDVD it's still quite a weapon, and the rip options (like no file splitting) still surpass much of the competition. -
What other current tools can demux and entire DVDR and spit it out by chapter or as one giant chuck of video?Originally Posted by Krispy Kritter
DVD Decrypter is fine. The problem is the DVD+VR spec, blank media, and the fact that machines don't age gracefully.
The spec makes it more difficult, but the ultimate problem lies in the disc. DVD+RW does not last long. Some DVD+R do not write too well in RW Alliance machines. I've never had a RW machine that was flawless on DVD+R and DVD+RW media, especially in most recent years.
Even Sony and TY DVD+R can be screwed up by burners. Remember many of those machines use old stock DVD burners, so the firmware is way out of touch with modern discs.
Computer burners and readers can also be finicky with discs, not wanting to read them.
Solution: Different discs.Want my help? Ask here! (not via PM!)
Copying DVD's with Shrink and decryptor
By LeeRobertE in forum DVD RippingReplies: 6Last Post: 26th Feb 2011, 15:46 -
What kind of bed do you sleep on?
By johns0 in forum PollsReplies: 21Last Post: 9th Jan 2010, 07:58 -
Universal remote controls for Daytek/Liteon/ILO HDD recorders
By oldfart13 in forum DVD & Blu-ray RecordersReplies: 16Last Post: 16th Feb 2008, 09:07 -
Is the time finally right for you to get bluray and/or hd-dvd?
By yoda313 in forum PollsReplies: 97Last Post: 26th Jan 2008, 13:22 -
What is the Deal w/ Liteon Recorders? Invalid Disc errors?
By peggypwr1 in forum Newbie / General discussionsReplies: 3Last Post: 21st Dec 2007, 23:00
