    Apr 2007
    I am uploading dvd's to my pc, uploading them to internet and sending them to people.
    I convert .vob to .avi or .mpeg (both seem to be around the same sort of size). Is this the right format to use?
    My uploads take hours - 422mb is taking 7hrs with 4 still to go, 222mb ish takes 2hrs at most but some files take much longer.
    All my dvd's are in parts usually 4 there is one which is over 1gb when converted, I can't upload over 1gb so was wonderign what I should do.
    Am I doing it right? I use NERO to copy DVD to DVD and DVD Decrypter to copy to PC then cinemaforge to convert. DivX doesn't want to work on this PC
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    What are you trying to accomplish here? DVDs are big - 4 - 8 GB mostly, really not suited for Internet distribution.
    DivX/XviD AVI is better, or maybe wmv.
    /Mats
    Apr 2007
    the most one of my DVD's is is 3GB. Each part usually converts to "00-300mb which is fine but some seem to take ages to upload with megaupload or sendspace
    Apr 2004
    Miskatonic U
    What is your connection speed ?
    Read my blog here.
    Apr 2007
    at work a business connection whatever that maybe all I know is that it's fast.
    Parents - 1 pc on 2gb I think
    Home - 4 PCs using the same connection to this one is really slow
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    All of the free upload services are over burdened with pirate activity, so don't expect them to as fast as your connection. Work connections, while they may appear fast, are shared, often between many hundreds of users. They also often have Quality of Service settings that ensure an even go to all users, or priority to certain applications. Uploading video to free file share services probably does not count as a priority application.
    Read my blog here.
    Apr 2007
    I can upload to my own host but then people can only view not download
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Reminds me of the expression "like sucking a golf ball through a garden hose". Movies/DVD's are HUGE amounts of data....period. Royal Mail is faster and probably cheaper in the long run.
