Hello,
I have a Sanyo DVD player.. I use it to play Audio CD's threw my TV. However when I play songs the TV shows a plain blue screen which is annoying. I can change the mode to black and white to get a black screen which is better. I am wondering if it is possible to install a visualisation plugin like winamp has, but for the DVD player. So when an audio CD is playing, a visualisation plays on the TV instead of a blank screen.
actually you could just leave the tv off. If you are just playing audio cds then there is really no need to send a video signal off of it (Only problem could be if you are using the tv as a speaker - in which case you might think about hooking it up to a pair of amplified computer speakers using a simple rca-to-headphone adapter). Unless you need to change tracks frequently and need to know the spot its playing its probably best to leave the tv off. You can still use the remote while the tv is off. If your player has a on unit display screen than you can still see what track number it is.
Two audio tracks playing at the same time?
By churchie04 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 9th Apr 2012, 22:34 -
ASF problem playing audio
By Neomorpheus in forum Software PlayingReplies: 2Last Post: 14th May 2011, 02:56 -
How do I: Record Video, Audio from MIC, AND Audio playing from speakers?
By miimaster2 in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2011, 20:51 -
Playing one AVI in WMP there's no audio
By mahogany in forum Newbie / General discussionsReplies: 0Last Post: 25th Dec 2010, 14:05 -
audio not playing in mkv but mp4
By briankh in forum Software PlayingReplies: 2Last Post: 11th Aug 2010, 22:15
