i have a sony g120a, flashed to a lite-on 165p6s msop firmware. i use dvdfab platinum for my backups. my ripping speeds will start out between 6-12 MB/s, depending on the disc, and drop to 1-2 MB/s sometimes even lower. the drive will make a "clicking" sound while reading. however when i burn my speeds and quality are fine. ive reset dma, uninstalled secondary ide, disconnected the cables and reconnected, checked master/slave jumpers, enabled/disabled smart burn, upgraded to mv96 and mv9n test firmwares, even went back to sony myr5 and myr6 firmwares, uninstalled dvdfab and reinstalled to earlier version, ran hdd cleaners, spyware/adware cleaners, registry cleaners, disk defragmenter, system restore... still no difference in ripping speeds. ive tried backing up original and backup dvds, both same results. ive went back to msop firmware because when my drive was working correctly i received better burns. nero cdspeed will create disk and give quality reports with no problems and i can watch dvds with vlc media player.
what is with the clicking sound and slow ripping speeds?
thanks troy
My first guess would be a hardware issue. Drives typically don't make clicking noises, which could be a tracking related issue. It could also be an aging/failing laser which is causing read issues/errors. In any case, there isn't much else that you can do except replace the drive.
Google is your Friend -
That's weird. Cable issues typicallyl result in data transfer problems, both reading and writing. Neither of the issues that you fixed would cause the drive to make clicking noises.
Glad it's working for you.Google is your Friend
Converting AVCHD Lite for editing in Vegas10 and then to a good format.
By Domiel in forum EditingReplies: 11Last Post: 24th Nov 2010, 10:11 -
HandBrake Good, but soooo slow
By dzachau in forum Newbie / General discussionsReplies: 2Last Post: 23rd Oct 2010, 21:04 -
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
Good Antivirus and firewall software for a slow ooooooooooold machine.....
By Noahtuck in forum ComputerReplies: 3Last Post: 8th Jun 2008, 03:21 -
vLite - Vista Lite ANy Good
By mn072065 in forum ComputerReplies: 4Last Post: 19th Jul 2007, 17:37
