Results 1 to 9 of 9
  1. i do have mp3 trim but i want to cut songs by listening to them & not by remembering frame number or time where one song will end & other will start etc.
  2. atleast someone answer me pls.
    Canada
    check ur email
  4. Cooledit will allow you to listen and trim/cut/add/etc. on the fly. You can find (demo) at http://www.download.com
  5. Banned
    Mar 2003
    WI
    You can imprt them into Vegas Video and listen to the songs and when you find a part you want to cut just hit the "m" ket and it will place a marker in the timeline so you know where you want to edit.
  6. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Don't you think that you are replying to a dead thread?
  7. Banned
    Mar 2003
    WI
    No, I care about all the posts here, even if they might be slightly old, I do what I can to help everyone, even posts from the past may contain someones question of the future.
  8. Goldwave is a good programme but you'll also need to download the lame file which are both available from goldwave
    to download goldwave
    http://www.goldwave.com/release426.html
    to download lame file
    http://www.goldwave.com/faq.html#mpeg
    Looks complicated but its really easy to use, just follow the instructions on how to install the lame file and the best programme out there...
    kas187
  9. Try MP3Splitter,just play and split,it's easy and free.
    http://www.webattack.com/get/megamp3split.shtml
    Four free must-haves to work with mp3's are:
    1.CDex
    2.MP3Gain
    3.MP3Splitter
    4.MP3trim
    All of which you can find at the link above.
    BTW...I like responding to the dead
