  1. Member Tbag's Avatar
    Mar 2006
    I have a large avi file that i tried split and convert to mpeg so i can burn 2 vcd's using total video converter but my laptop keeps shutting down through the coversion.
    I then tried DivXToDVD but it did the same through that.
    is there a way to burn the avi straight to a disk with the coversion? (but still playable in dvd player)
  2. Member Soopafresh's Avatar
    Jan 2004
    If your DVD player can play DivX files, then yes. Some models can.
  3. Member Tbag's Avatar
    Mar 2006
    i dont think it can
  4. Mod Neophyte redwudz's Avatar
    USA
    What's the AVI format? Post a Gspot screenshot if you like. https://forum.videohelp.com/topic271697.html
  5. Member Tbag's Avatar
    Mar 2006
    never mind it worked without shutting down, thanks anyway
