Can Nero Recode be used to convert mpg an vob files to avi to run on an Archos 604 and 704? Can Nero Recode convert a wmv file to avi? What other tools are suitable for this?
	I don't know about Nero Recode, but these seem to be the specs for the 604:
 Nero Recode does do H.264, which is a very compact format, but takes a lot of CPU power to encode at any good speed. I don't think it converts from WMV, but not sure.Video playback**: MPEG-42 (ASP@L5 AVI, up to DVD resolution)
 WMV (MP@ML, up to DVD resolution).
 With optional software plug-ins:
 - H.264 up to DVD resolution and AAC sound.
 - MPEG-2 MP@ML up to 10 Mbps (up to DVD resolution) and AC3 stereo sound.
 Audio playback**: Stereo MP3 decoding @ 30-320 Kbits/s CBR & VBR, WMA, Protected WMA, WAV (PCM/ADPCM).
 - AAC3 music files
 - AC3 stereo sound files
 Or you could use a few individual programs, mostly freeware to accomplish the same thing. AutoGk can get you Xvid or Divx encoded files from a decrypted DVD. Or FairUse Wizard.
 WMV from Windows Media encoder.
 H.264 from MeGUI.
	yes as long as your mpg files are with the specs for the archos you can just load them straight on to the player. If you want to compress them into smaller files like divx than you need to convert. Virtualdubmod or virtualdubmpeg2 is another good converison program. I believe the latest versions of both programs accepts wmv files. Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	So what choices (menus/selections) do I make in Nero to make the video files Archos compliant without plugins?
  Recode Avi Using Nero 7 Always Turns Up UglyBy Mustang in forum DVD RippingReplies: 6Last Post: 18th Aug 2010, 03:16
  [Archos 605] transform from 720p.HD.DVDRip.XviD.AC3 to Archos format ?By birdwing in forum Portable VideoReplies: 2Last Post: 6th Nov 2009, 00:41
  archos 7 VOB files and subtitlesBy stevencg in forum Video ConversionReplies: 3Last Post: 31st Jan 2009, 19:17
  Archos 604 - Nero AVC audio problemBy sungpark71 in forum Portable VideoReplies: 7Last Post: 19th Dec 2007, 08:49
  Archos 404 & DVR stand vs Archos AV 500 - difference in MPEG-4 recordinBy DavidMcGowan in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2007, 06:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
