    Jul 2007
    Hello,
    I have a few movies on my HDD. I am not sure about the rest of the movies but at least one of my movies is in English but it has a different language at the bottom of the screen. All my movies has the .sub files. How do i get rid of the foriegn language whatever language it is? Is there a guide for it? Does anyone have a direct link for a guide?
    I don't understand, just remove the sub and you should not see any subtitle? Or do you want to remove one language from the sub/ifo file? Or are they permanent non-switchable subtitles?
    Jul 2007
    Originally Posted by Baldrick
    I don't understand, just remove the sub and you should not see any subtitle? Or do you to remove one language from the sub/ifo file? Or are they permanent non-switchable subtitles?
    I am not sure what subs they are but how do i remove it? It is the words at the bottom.
    If you remove the .sub file do you see the foreign language when you play it?
    Jul 2007
    Thank you so much Baldrick
