I have tried ripping video from a DVD source with DVD Decrypter and DVD Shrink, and when I plug it into MVW, I get motion issues, slight skipping and such during high motion scenes. Is there a way I can rip the DVD source and avoid these motion issues? Thanks.
If it is from a recent commercial disc then you may need to use newer ripping tools such as DVDFab HD Decrypter or the latest AnyDVD. DVD decrypter and DVD Shrink, while still useful tools, cannot handle the protection of many discs released over the past year or more.
If it is from a non-protected source then you may need to clarify the problem more.
1. Does the skipping occur if played back using a video player (MVW is an editor, not a player) ?
2. Does the skipping occur prior to editing, or only after editing ?
3. What does 'motion issues' mean ?Read my blog here.
It is from a protected source.
1. The skipping occurs in other players
2. Prior, but I have had it happen post-edit in the past
3. Almost seems like frame skipping.
I'll try another ripper and see if that helps, thanks for the tip.
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 04:46 -
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 21:28 -
Fairuse Wizard issues: Bad video and muxing failure.
By octick in forum DVD RippingReplies: 2Last Post: 28th Apr 2008, 16:51 -
By newshoes in forum Software PlayingReplies: 10Last Post: 20th Mar 2008, 11:22 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 09:52
