My apologies if this question has already been asked and answered.
So I wanted to encode multiple MOV files to MPEG-4 so that I could burn them to DVD using DVD Creator (I like this program because I can make custom menus and actually put music on the Menus screen). Anyhow I was encoding the MOV files and while ffmpegX was able to work on some of my MOV files, others it failed. There didn't seem to be any difference in the MOV files except I noticed something on the summary screen on ffmpegX.
Apparently the audio of the movies that ffmpegX COULD encode listed the audio as: qdm2, 11025hz, mono. However, the MOV files that failed had audio listed as follows: Qclp/0x706C6351, 11025Hz, mono.
Anyone have any ideas why this is and how can I get it to work?
qdm2 = QDesign Music 2 audio codec
Qclp = Qualcomm PureVoice audio codec
The latter is not supported by the current ffmpeg engine. However, the mencoder engine does support it. So, if you DVD authoring app supports H.264, then you could use ffmpegX's h.264 mencoder preset to create an MP4 file. -
Thank you very much for the prompt response AND the information, Case. With those definitions and your suggestions I was able to successfully finish the MOV's that would not encode. Thanks again
mov to flv framerate issue with ffmpegx
By Sebbeto in forum ffmpegX general discussionReplies: 5Last Post: 23rd Mar 2010, 01:20 -
ffmpegX doesn't seem to want to convert .mov to flash
By biebs in forum ffmpegX general discussionReplies: 7Last Post: 19th Feb 2010, 14:50 -
ffmpegx problem: no audio from QT mov to avi
By mekon in forum ffmpegX general discussionReplies: 5Last Post: 1st Feb 2008, 17:14 -
FFMPEGX problems- MOV to AVI
By ker-plop in forum MacReplies: 8Last Post: 30th Oct 2007, 12:43 -
.MOV to VIDEO_TS How? [ffmpegX] [DVD2ONEX]
By bonespur in forum MacReplies: 5Last Post: 26th Jul 2007, 09:48
