hi i have an iso thats 8,240,370 kb which is bigger than a dvd disc and was wondering how do i make it smaller without changing anything?
edit: sorry if this is the wrong section
First off, an ISO is just a disc image file. Could be an image of anything: DVD-Video, AudioCD, VCD, Playstation, HDD Ghost backup...
ASSUMING it's a DVD-Video, you ought to mount the disc with something like DaemonTools, then use DVDShrink or similar to create a new ISO that fits an SL disc, and then burn with something like IMGBurn.
Scott -
ok, i have daemon tools and know how to mount, but what do i do with dvdshrink?
ive tried searching for solutions on how to use dvdshrink before posting but i havent been able to see the right one that i needed... i tried searching for dvd clone also and havent been able to find the how-to's -
If it's a DVD inside that ISO, then run it though DVD Shrink and transcode to a smaller file. Shrink accepts DVD ISOs. That will reduce the size. Or if you want a minimal hit on quality, use a program like DVD Rebuilder to re-encode the file. You may have to extract it first to the DVD format with a program like ISOBuster. But that may take quite a bit of time for the encode, depending on your CPU speed.
Or if it is DVD compatible, burn to a dual layer disc as is.
http://www.afterdawn.com/guides/archive/how_to_copy_dvd_with_dvd_shrink.cfm or http://www.digital-digest.com/articles/dvdshrink_4_dummies_page1.html
There's a few more in our 'HOW TO'>Convert' guides to the left. <<<<<<<
How can i make subtitle bigger or smaller (SUP File Format)
By Charmer in forum SubtitleReplies: 9Last Post: 2nd Jun 2009, 15:43 -
Can I make a AVI file smaller?
By baebbe in forum Newbie / General discussionsReplies: 7Last Post: 15th Aug 2008, 16:04 -
How do I make a AVI Smaller?
By gottiman in forum Newbie / General discussionsReplies: 2Last Post: 2nd Dec 2007, 05:35 -
How to make an audio file smaller?
By aruwin in forum AudioReplies: 13Last Post: 29th Jun 2007, 23:01 -
Want to make 1GB ASF smaller
By jabroni in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2007, 00:01
