does it take to accomplish that with any degree of quality in the converted video?
Thanks!
Bruce
If those are anything like .ts or .tp hdtv recorded files I'd try out projectx. With that there is a good chance you can demux it to m2v or the equivalent and then convert from there.
EDIT - also check out virtualdubmod or virtualdubmpeg2 - be sure to get the latest release of either of them. I don't know what the newest ones support in terms of high def video files. But the normal virtualdub will only read avi file types (that i know of - will not do mpg or vob for sure).Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
What are you going to do? edit the video? then get a video editor that supports hdv directly.
Or do you want smaller file size? -
Yes,the goal is to convert the .m2t file to .avi so it would be suitable for editing.
I'm using sort of a "stoneage" program (Adobe Premiere 6.5) compared to what's out there currently,however... that's what I know best and have the most editing experience with.
As you probably well know,Prem 6.5 was not designed to handle/import .m2t files at all!!
Hence the origin and reason for my question.
Here's a wild idea which is not my own,someone on some forum (can't remember where) said they changed the file extention from .m2t to .avi but I've never tried it.
Thanks for any help offered.
Bruce -
Read this thread for some ideas. Wrote a script which should auto convert an m2t to a Lagarith encoded AVI, suitable for editing.
https://forum.videohelp.com/topic303573.html
HDV M2T not bluray compatible
By FrontierDK in forum Video ConversionReplies: 4Last Post: 2nd Feb 2012, 09:33 -
Best way to batch convert xvid/avi files to mkv/x264 files?
By gaikokujinkyofusho in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 06:31 -
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
How to use .M2T files on the Mac
By ArthurDaley in forum MacReplies: 7Last Post: 10th Apr 2008, 03:56 -
What is the best /.m2t/HDV file player(s) for the PC?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 28th Sep 2007, 17:04
