Hi everybody.
Til now i've been using TMPGEnc 4.0 Xpress , to Encode AVI movies to DVD MPG, and author them with DVD Lab Pro.
But the method with TMPGEnc 4.0 Xpress is too long for me [with Low Start is about 3 hrs, and with standart about 6 hrs)
Is there any way to encode files faster and to save quality 100 % like AVI File.
Thanks.
Ardiani.
if you want 100% quality the only way to do that is to keep it in its original form. In order to do that you should get a dvd player that reads divx files. Then simply burn them as data.
Otherwise you have to go through the conversion process which will take time. The only way to speed up the conversion is to get a faster computer - say a core2duo or a quadcore computer.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Aha, OK , I will get a faster computer, but is a good way to encode with TMPGEnc 4.0 Xpress or any other way.
Sorry about writting in wrong section. -
You could try ConvertxtoDVD also to encode. It may be faster than TMPGEnc 4 Xpress. However, I personally prefer the latter.
Enconding Megui Xvid error :/
By psygno in forum DVD RippingReplies: 0Last Post: 2nd Sep 2011, 06:27 -
xmedia Recode - Where can I find these enconding parameters?
By TYLER08027 in forum Video ConversionReplies: 3Last Post: 6th Nov 2010, 14:40 -
Vp6 enconding?
By Vicfred in forum Newbie / General discussionsReplies: 10Last Post: 31st May 2009, 15:47 -
4:4:4 enconding - which program, which method?
By waefwaeefwaefw in forum Video ConversionReplies: 6Last Post: 19th Jan 2009, 13:35 -
Enconding problems: flickering, horizontal lines and choppiness
By F u r u y á in forum Video ConversionReplies: 13Last Post: 25th Jan 2008, 01:44
