Does anyone out there know a way of getting Audio DVD Creator to burn several DVDRs of a project in one go? I'm fed up with waiting for the files to be converted again for every copy I want to run off.
Just tick the "Create DVD Files to hard disk" option instead of "Burn Audio DVD Directly" in step 5, then use ImgBurn to burn as many copies as you like.
/Mats -
Exactly what mats said...
I have used this tool for many moons, and even though i usually never do more than one copy, i still prefer to let it save to the hdd first to test and make sure everything is okay before burning the final product to a dvdr.
You should look a little better before leaving a complaint under comments for a tool 8)
Help burning Pinnacle project to DVD...mpg, converting, etc.
By jubbilee in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2011, 14:37 -
Editing a project in HD, but burning to DVD in SD...
By Huntr777 in forum MacReplies: 6Last Post: 14th Jun 2011, 20:20 -
DVDSP output multiple copies?
By MikieV in forum MacReplies: 10Last Post: 8th Dec 2010, 11:10 -
faster way to make multiple home dvd copies
By DirtBikeMike in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2010, 11:37 -
Multiple Copies of VOB files when copying dvds
By sativa36 in forum Authoring (DVD)Replies: 4Last Post: 17th Dec 2008, 16:29
