I ripped a DVD to my PC using DVD Shrink, which created VOP, IFO, and BUP files, less than 4 GB total.
I used ImgTool, as recommended here, to create an ISO file from those files. However, the ISO file it created is around 7 GB, too large for a DVD. Any idea why this happened? Or how to fix it?
Thanks,
Chris
Closed Thread
Well, this thread was started 5 years ago, and last had any meaningful content 3.5 years ago. Chances are pretty likely that the info is out of date.
If you have the VOB, IFO, and BUP files, then all need is ImgBurn, and select "Build" mode and change the Output to "Device" and you can burn the video files to the DVD directly without making an ISO. If you want an ISO, ImgBurn can do that too, Output->Image file and then you can burn the ISO using "Write" mode.
Guides & FAQs for ImgBurn here:
http://forum.imgburn.com/
Jim
This is also a duplicate of the question you asked in: https://forum.videohelp.com/topic337596.html#1756744
Locking this thread. In the future, please do not post the same topic in two forums.
How do I make a dvd data disk from these vob, bup, and ifo files?
By DHarry in forum Newbie / General discussionsReplies: 4Last Post: 4th Jul 2011, 04:23 -
Function of .IFO .BUP .VOB files on a DVD?
By brassplyer in forum Authoring (DVD)Replies: 6Last Post: 14th May 2008, 21:27 -
Downloaded VOB, BUP IFO files won't play in dvd player
By COOPERMAN100 in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2007, 05:31 -
VOB/BUP/IFO to AVI???
By chronic777 in forum DVD RippingReplies: 6Last Post: 11th Aug 2007, 12:10 -
*S.O.S* No Sound when burning VOB-IFO-BUP Files to dvd
By Zaii in forum Newbie / General discussionsReplies: 3Last Post: 30th Jul 2007, 04:46
