Since upgrading to the new 6.7 DIVX codec, I have found that Ulead movie factory 3 will no longer accept Divx avi's. When I try and add them Ulead seems to lock up and the little Divx icon keeps appearing and dissapearing in the system tray, as if its trying to work but somethings wrong.
I used system restore to revert to the previous codec and now all works well again. So how come problems occured when I upgraded?
Also, as a side issue, how come Divx files take so long to convert? Mpegs usually only take an hour or so, I had to leave the PC on overnight and well into the following morning just to convert a 40min 300mb video to DVD?
TIA
I guess you have to ask ulead why it wont work and hopefully will they release a fix for it.
Have you tried convert to dvd with something else? Ulead is not the fastest around. Maybe try ConvertXtoDVD but you can't make that nice menus then.
Converting Divx to VOB - having problems.
By martinlest in forum Video ConversionReplies: 9Last Post: 6th Mar 2012, 17:23 -
Creating a DVD Menu for multiple divx files without converting them
By LGT in forum Newbie / General discussionsReplies: 23Last Post: 21st Jul 2010, 14:04 -
Converting DIVX .AVI Files to DVD using Nero Vision 8 and 9.
By nnhood in forum Authoring (DVD)Replies: 2Last Post: 26th Jun 2009, 19:09 -
Problems converting Multiple .avi files w/ subtitles to DVD
By bwanis in forum MacReplies: 2Last Post: 30th Nov 2007, 13:23 -
Problems while converting ts files
By vertical in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jun 2007, 14:01
