Hi,
What does everyone recommend in a movie leave it as an MPEG audio or convert it to ac3? If you say convert it, how how do i convert it? I used ffmeggui to convert the MPEG to ac3 then i used VirtualDubMod to Demux it out. When i used my authoring program to add the audio back in, I got no sound. I know after DeMuxing it i tried to save the video but i couldn't. I got a message saying FAT32 can not save more then 4 gigs. Could i use VDMod to convert from MPEG to ac3 audio and is there any guides for that conversion?
Results 1 to 10 of 10
There are many free and for money programs that will do the job. Look in tools or do a Google search to find them.
Could you give me a name of a free tool?Originally Posted by pepegot1
Yes you could use VDMod.......you need the AC3ACM codec....
Look here for guides on Vdub...
http://www.doom9.org/" Who needs Google, my wife knows everything" -
What authoring program are you using? Some authoring programs let you convert to ac3 like tda with the ac3 plugin.
And try convert to ac3 with something else than ffmpeggui like aften but it only accepts wav so you would have to convert the mpeg audio to wav.
And convert one of your hdds to NTFS and you wont have any 4GB problems!
What version of tda? latest versions should support ac3 encoding directly or if you have 1.5/1.6 you need the ac3 plugin($30), http://tmpgenc.pegasys-inc.com/en/product/tsp_ac3.html
How to convert 5 ch. AC3 to 5 ch. MPEG-2 Layer II
By macman241 in forum AudioReplies: 21Last Post: 1st Sep 2016, 12:08 -
MKV files with Audio in DTS need to convert audio to AC3
By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 09:17 -
Convert MKV with ACC audio to AC3 audio for PS3 playback
By wolvie77 in forum Video ConversionReplies: 4Last Post: 25th May 2010, 11:13 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 16:25 -
MPEG2 Video with AC3 audio cannot convert to MP3 audio
By wenglock in forum ffmpegX general discussionReplies: 0Last Post: 7th Sep 2009, 22:52
