I have TMPGenc and used it for about a week and now I cant use anything because it says my trail period has endedI downloaded an older version just in case it was because you have to buy the latest one out, but I got the same message. Is there a place I d/l it from for free (isnt it freeware n e way)? - I also made a copy of a R1 fast and furious DVD into SVCD there are 3 files of 700MB each is this normally this big and will i need to use about 5 700MB cds to fit it on?
thanks
This is that block of text which gets added to all the posts I create. There is a 255 character limit.
SVCD is Mpeg2 and the mpeg2 encoder isn't free. It has a 30(14) days trial period.
Tmpgenc 12a hasn't any time limitation. -
Hi!
WOW ..... one question at a time guy!!
TMPGenc didn't used to have any time limitation on the MPEG2 encoding function (hence Jestorious' tip about v.12a)
However, the technology behind the MPEG2 compression format is patented and therefore needs a licence if software developers want to use it. Therefore, there were a few strong words aimed in the direction of the group that makes TMPGenc a few months ago.
So now, MPEG2 encoding is limited to a quick trial so as to keep the licence holders happy!
The good news is that it's not very well protected and is very easy to get around (done on purpose I think!).
All you have to do is put your system clock back, say, a year. Then you will have 30 days left for ages!!
You can now buy TMPGenc PLUS. You should consider doing this if you're going to be using it a lot. You'll get support, upgrades etc for a very small amount of dosh!
Soon to come is TMPGenc SERVER which will probably cost more but has some great functions (like 20pass VBR encoding !!!!)
As for your multiple disk thang ....... it all depends on what bitrates you used to encode the SVCD. The higher the bitrate, the better quality of picture BUT the bigger the final MPEG file !!
General opinion is that you can encode an MPEG2 file for SVCD with a pretty good picture and sound, and get around 60 minutes per 80min(700mb) CDR.
(BTW - you can now buy 99min CDRs. Not all burner's can use them fully so check for compatibility!)
Hope this helps .....
Sue xxx
Sue your cool. Cheers!! xx
TMPGENC question
By triumph2004 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Aug 2008, 23:21 -
TMPGEnc question.
By Hal05154 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 08:20 -
TMPGEnc Question
By dafoe in forum EditingReplies: 5Last Post: 12th Oct 2007, 04:38 -
TMPGEnc XPress 4 Question
By Anakin in forum DVD RippingReplies: 1Last Post: 24th Aug 2007, 23:08 -
Patching SVCD to DVD question
By zanos in forum Authoring (DVD)Replies: 22Last Post: 29th Jun 2007, 09:17
