Hi all-
I seem to have an ongoing problem when attempting to backup large DVDs. For example, I have several DVDs with TV shows on them (Mission Impossible for example). If the DVD has just two episodes on it, I pop it in the PC and it opens right up. If the DVD has 4 episodes on it (3hr 32min.) my Plextor 716a won't open it. I just get a continuous flashing orange light stopping me cold. This only seems happens on the 3hr+ discs. has anyone else had this problem or am I just imagining this whole thing :>)
Thanks,
Mark
Give us some more details...
What DVD Authoring software are you using? What DVD media type are you using? DVD-5, DVD-9? What kind of source file? What compression rate are you using for 4+ episodes?
My best guess for your Plextor LED to flash and not respond is likely Media type is bad or your Drive is bad. -
Are you asking about Windows Explorer not being able to open the DVD disc? In other words, you haven't been able to open or play the DVD with your computer? And you're not asking about opening it in your back up programs? In other words, ripping it to your hard drive?
Either way, that's sounds like more of a Windows or software problem, unless the discs you are trying to back up aren't commercial discs. If they're not commercial pressed discs, as mentioned, it could be a disc problem.
But it doesn't sound like a problem with the drive. At least not for just opening the disc.
And it would be very helpful to tell us the software and procedures you are using.
Can't Open a VERY Large MP4 File?
By ShadowfaxSTF in forum Video ConversionReplies: 3Last Post: 27th Jun 2011, 11:50 -
Large MKV split on two DVDs
By bjb39 in forum MacReplies: 2Last Post: 1st Dec 2009, 21:01 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 16:03 -
Ripbot 1.13 won't open
By wulf109 in forum Blu-ray RippingReplies: 2Last Post: 9th Feb 2009, 10:45 -
DivFix++ v0.30 won't open
By Bix in forum Newbie / General discussionsReplies: 3Last Post: 26th Jun 2008, 23:40
