I am having some problems with Premiere Elements 3 when trying to edit a video and encode it to an FLV file.
The original file is a WMV, and is 480x270. I did my edits, and am trying to export to an FLV file, but the FLV is always smaller than the original dimensions. I do not understand why.
If I save as a WMV file then the dimensions are OK. This is the only way I have been able to get this to work: 1) output file to WMV then 2) use Flash encoder to encode to FLV. This is obviously tedious and should be unnecessary since PE3 can export to FLV directly.
Interestingly, I downloaded the trial for Premiere Pro CS3 and the output dimensions are correct.
I would upgrade to Pro CS3 but unfortunately missed the $299 promotion, so I am stuck with Elements.
Results 1 to 1 of 1
Adobe Premiere Elements
By willmington in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2011, 04:14 -
Rendering in premiere elements 8!
By cnl1339 in forum EditingReplies: 3Last Post: 27th May 2010, 17:58 -
Premiere Elements 7 -- letdowns so far
By jg0001 in forum Authoring (Blu-ray)Replies: 1Last Post: 29th Oct 2008, 23:02 -
Premiere Elements 4 HELP!
By tczerwinski in forum EditingReplies: 3Last Post: 28th May 2008, 09:55 -
Premiere Elements 3.0
By sm head in forum Capturing and VCRReplies: 2Last Post: 28th Jun 2007, 15:42
