I don't know if this is one problem or 2 different ones. When I try to open 30fps files in TMPGEnc 2.5 it automatically treats them as a Film Movie (24fps) and that's easy fixable by just changing the tab to Video Movie. But I'm having the same thing happen in TMPGEnc DVD Author, it says the 30fps files are 23 or so fps and won't let me use them, and in that there's no option to adjust it to the proper fps. Essentially both programs are not reading the files as 30fps video files (and they are). Anyone know how to fix this? Could this be a codec problem?
Thanks,
Kevin.
Hi,
It is happening with some .xvid files in TMPGEnc Plus but it's also happening with .vob files that i'm putting in DVD Author, files (30fps) that worked fine before, now DVD Author is reading them as 23 or so fps and won't let me use them. -
What version of DVD Author do you have? For the XVID on TMPGEnc 2.5, I was able to fix it with an older version of XVID... something wrong with TMPG and XVID codec I guess.
I'm surprised VOB would be different since its pretty standard so fps reading isn't usually wrong. It might be using 3:2 pulldown? Try converting it to MPEG-2 DVD compliant with TMPGEnc 2.5. What does GSpot say about those vob files?
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 12:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 15:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 16:58 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 18:56
