Hi,
New poster but long time SVCD2DVD user.
I have never had any major problems with this program it just seems to work or any minor problems are fixed quickly.
I am having a problem now. Version 2.1 would allow me to add assets from my networked computers but Versions 2.5.3200 and 2.5.3300 will not let me add them. Tried double clicking, single click and Open and dragging file to assets. Nothing happens, box goes away and assests are empty.
If I run the old v2.1 it works fine. If I copy the files to the main computer that SVCD2DVD is running on they load as assets fine.
I had been using v2.5.3200 but just downloaded v2.5.3300 hoping that would fix it but it didn't.
Did a search on forum for 'network' but found no answers.
Not a big problem but it would save me a lot of time if it was working.
Thanks for you help.
John
I will look into it.
Thanks for your help.
I have checked everything on this end and I can't find any problem.
As I said it works okay with v2.1 but not with v2.5.
I can see the files on the network but cannot add them to the assets window.
John -
I have fixed this for the next release. Thanks for the headsup.
This should be fixed in the latest release. Please let me know.
Hi ChrissyBoy,
Just tried the new version 2.5.3500 and everything seems to work okay.
I can now add networked assets.
Thanks, keep up the good work!
John
Drag and Drop Assets
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th May 2011, 04:37 -
Add WAP or Wireless Router to Existing Wired Network
By theweight99 in forum ComputerReplies: 7Last Post: 28th Aug 2009, 10:25 -
How do I move assets from one project to another?
By Anaheim in forum MacReplies: 1Last Post: 1st Apr 2009, 23:14 -
Network printer on separate network?
By Lucifers_Ghost in forum ComputerReplies: 7Last Post: 5th Dec 2008, 13:52 -
Assets problem
By tandaman in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 7th Jul 2007, 18:25
