I've been using the AIW Radeon for about a year now! I WOULD like to use it to capture via the "IN" from the SAT. Briefly, to get good quality, I've gone through 2 processor changes (PIII 733 - PIII 1GZ), innumerous driver changes, (Finally got MMC 7.5), and 1 Motherboard change (ASUS), and 1 OS change (W98 - XP)..
Now, under XP things have settled down, but here is the problem:
When I start up the capture, it looses a lot of frames in the first few seconds (i.e. 20%), after which it stops loosing (you see the percentage progressivly drop to < 1%). This would be fine, 'cause I could easily edit out the first few seconds, BUT Apart from using the File Player in MMC, I can't open the .mp2 with anything else for editing / recompression:
TMPGEnc and Virtual Dub complain of Packet Syncronisation Errors, Flask hangs, etc..
Looking at the Task Manager, the system peaks out at 100% CPU for about 3 secs, and then settles down at approx. 65%
I'm sure that the culprit is the first few secs of scrambled video. It's almost as if initially the disk writes are too fast for the OS, and subsequently things Pick Up.
My system has 128mb Ram, 2 HD (configured in DMA), Intel 815EP chipset and the Intel Application Accelerator installed (which DOES speed up a lot of things)
What I would love you to help me with is:
1) What can I do to improve the capture frame drop
2) what can I use to edit/convert/recompress these movies?
Thanks!
Sorry i cant help with your question, but where can i gte MMC 7.5?
I purchased an AIW Radeon, but it came with MMC 7.1
thanks
Win -
for 7.5 try http://stinky.dosrules.com also a nifty litle aiw tweak tool
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 17:12 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 01:24 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 02:28 -
More ATI MMC questions. (I RTFM'd.)
By palouse in forum Capturing and VCRReplies: 5Last Post: 13th Jun 2007, 20:08 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 22nd May 2007, 23:44
