My HD TV, like most, offers several options for display settings like Auto, Wide, 16X9, 16X9 with subtitles, etc. On some broadcast signals, all of these choices are available for me to use. On others, only Auto and Wide are active with the rest greyed out. When this occurs, Wide is usually the wrong choice and Auto sometimes causes the picture to expand and contract during the broadcast, which is mildly annoying. Can one of our experts enlighten me on what is triggering these options and why Auto seems to "get confused" during a broadcast?
I appreciate any education offered.
Regards,
Racingintherain
On my HDTV, all aspect ratio choices are available for analog NTSC/SD inputs but are limited for digital and HD inputs.
This varies by TV model.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks edDV. In the case in question, I am feeding an antenna into the coax input of the set. In this mode I am only watching digital broadcasts and yet the options vary between channel and show. HD broadcasts are no problem, but SD seem to occasionally provide this annoyance. No biggie, just curious.
Regards,
Racingintherain -
The question would be whether your TV has only a standard SD tuner or one capable of SD and HD. In which case, you are likely tuning to the HD channel which is broadcasting SD and HD material. This is especially noticable during commercials as the TV switches from HD to SD and also falls into edDV's comment above concerning restrictions on HD inputs.
Google is your Friend
HELP? - Need to record and broadcast digital video simultaneously.
By mpalm887 in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2011, 06:39 -
Digital TV Signals - Changing Frequency Question
By Frank-0-Video in forum DVB / IPTVReplies: 0Last Post: 2nd Feb 2009, 18:48 -
2009 digital broadcast transition clarification
By siratfus in forum DVD & Blu-ray RecordersReplies: 30Last Post: 2nd Aug 2008, 11:33 -
Broadcast signals starting to be copy protected?
By duffy76 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Jul 2008, 13:23 -
Digital TV Signals-receiving
By ldn354 in forum DVB / IPTVReplies: 9Last Post: 12th Sep 2007, 22:14
