Hello Group Members, I've been using TMPGEnc version 2.0 for many years now.
Last week, I tried making a regular DVD with a 65 second motion menu and for some reason cannot get any motion menu to work.
If I look at the vob files in the VIDEO_TS folder - the vob that contains the motion menu is present. So... why doesn't the motion menu work.
This is driving me nutty..! I've enabled all the motion menu options and still NO motion menu.
Thanks to all that reply.
Tug_Hill2
Reach for the Starz
guns1inger Posted: Sep 27, 2007 00:25
So what do you actually see when you try to play the results ?
Does TDA give you an error, or does it compile ?
Details, man (or woman), details.
Hello guns1inger, Thanks for the reply.
I receive NO error messages from TMPGEnc.
TMPGEnc compiles the DVD and I can preview the DVD & the motion menu and the video_TS directory contains the motion menu as a VOB.
But I don't get any motion.
If I play the DVD it autostarts with NO menu.
I do not use a top menu I always use the content menu only.
Thanks for any and all replies.
tug_hill2Reach for the Starz -
What do you have selected under Global DVD Menu setting > Disc insertion action? This is the very first thing that happens when you insert your Disc. If it says play all track then you won't get menu unless you click on the menu button on remote.
Then under motion menu, make SURE you have either "Motion menu(no audio) or Motion menu and background audio"... My guess is you probably accidentally selected "Still picture and background audio" which should enable the timer but you don't get motion background.
If you still have the original project then check it again. Preview it with a software DVD player before you burn onto disc. -
Hello nTekka
Thanks for the info. I'll check the settings and post the results.
Hello nTekka, All is A.O.K. now. I had the disc insertion action to the wrong setting. I put it as: Display the track 1 menu. And I can now see my motion menu...!
That was the only one that needed 'fixing' the others were set correctly.
Thanks for the 'fix'
MultiAVCHD - unable to make menu
By WARRENFRALEIGH in forum Authoring (Blu-ray)Replies: 3Last Post: 12th Sep 2011, 14:03 -
Can't open older TMPGEnc DVD Author files in latest version
By steelborn in forum Authoring (DVD)Replies: 1Last Post: 19th Feb 2008, 13:55 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 19:20 -
how to make motion menu in dvd-lab pro that like this
By 741210 in forum Authoring (DVD)Replies: 10Last Post: 23rd Aug 2007, 22:53 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 03:53
