My DMR-E50 isn't reading disks anymore, will a different Panasonic recorder read the unfinalized disks from my machine?
The same model should for sure. Not sure about different models, though I suspect they would also. If you are shopping at a B&M store, just take a disc with you and check.
Google is your Friend -
I have tested unfinalized disks made on a DMR-ES35V on a ES45V and the new EZ47K. They all play and I have finalized ES35V disks on the EZ47V and those all play on all the units as well. The E50 is quite a bit older than these however.
Yes, a friend had two DMR-50's which refused to finalize discs. He bought a pair of DMR-EZ75's to replace them and was able to finalize the discs with those.Originally Posted by jjis
I have an E80. You need to update the firmware. Go to:
http://www2.panasonic.com/consumer-electronics/support/Drivers-and-Downloads/list-DVD+Recorders# -
Clean your laser too. This is something that you should do at least every 2 years.
Panasonic homedeck 3d bluray recorders
By mazinz in forum DVD & Blu-ray RecordersReplies: 0Last Post: 20th Feb 2011, 16:01 -
Question on new Panasonic dvd recorders
By heman28 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 20th Feb 2008, 11:37 -
Panasonic DVD recorders AV-in NR (noise reduction)
By JoseD in forum RestorationReplies: 2Last Post: 4th Jan 2008, 23:04 -
Pioneer and Panasonic DVD Recorders w/HD?
By MCnDaHouse in forum DVD & Blu-ray RecordersReplies: 15Last Post: 16th Dec 2007, 01:48 -
New Panasonic Recorders with Hard Drive?
By duffy76 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 15th Jul 2007, 11:51
