    Dec 2005
    i seem to be having problems burning an iso to dvd-r
    i first used dvd decrypter to burn the iso and the disc seemed to burn and verify fine.
    when i tried to play the disc it froze about 10 seconds into the disc
    i took the disc out of the player and re-inserted it.
    i used the chapter marks to skip past the point where it stuck then rewound the disc to a point just
    before the sticky point. the disc played the rest of the way through.
    the blank media that i used was the notorious mis-labelled maxells supposedly mij but
    actually ritek.
    i then purchased some verbatim mij tygo3 and burned the iso again, this time i used img burn.
    again the disc burned and verified fine but stuck at another point during playback.
    i then tried burning a disc using nero which was ripped in file mode onto both the maxell and verbatim media.
    both discs burned, verified and played perfectly.
    i always thought that burning iso was a more reliable method but for me it seems the file mode discs are working better.
    this is the first time that i have had problems with iso,s.
    during both burns of the iso i noticed that the buffer for both dvd decrypter and img burn dropped really low,
    could this be the cause of the problem ?
    my main question is - is there any way to convert the iso to files so i can re-burn with nero ?
    this will enable me to work out wether the iso is corrupt or it is maybe a wrong setting in dvd decrypter or img burn
    which are both set to default setting.
    any help will be much appreciated
    many thanks in advance.
    wake up this planet is dying!
    Extract the content from the iso with isobuster, daemon tools, etc. Then burn the video_ts folder with nero or imgburn. If that wont work either it may be something wrong with the video, so you might have to reauthor or reconvert it.
