    Sep 2007
    I get an error when using the svcdvd tool
    INFO: [mplex] BUFFERING min 15 Buf max 683
    **ERROR: [mplex] MUX STATUS: Frame data under-runs detected!
    How can I fix it? Can I change some of the buffering settings?
    This is on an Intel Mac running ffmpegx 0.0.9x
    On a PPC Mac I have running 0.0.9t I don't get an error with the same file. For some reason though, I can only get it to convert a folder of mpgs to a dvd with chapters on the intel machine. The PPC machine will only create a dvd with one file/chapter. Any idea why?
    My complete log is attached.
    error%20log.rtf
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    A.
    If you're svcdvd'ing multiple files to one DVD, you may want to see if any particular one source file is responsible for the mux error, by trying several times and excluding a different source file each time.
    Else, you could try other authoring packages, e.g. Toast, Sizzle, DVDSP. Maybe they handle it differently.
    B.
    The difference in chaptering might be a result of the different versions of mplex in ffmpegX 0.0.9x r2 and 0.0.9t. The 't' version is from 2005, and the mplex in the current ffmpegX is from 2006. Just a guess, tho'.
