  1. Member scottb721's Avatar
    Oct 2002
    Australia
    Been tasked with making a 2hr clip featuring famous movie scenes/quotes.
    Source material will be from DVDs and was hoping for some suggestions of which apps will make this the least painful.
    Current thinking is to extract desired scenes as avi, edit and encode/author to DVD but that may be very time consuming.
    Any other ideas ?
    Use a mpeg2 editor,
    tmpgenc dvd author, add dvd video, cut, burn, author.
    videoredo, edit, save as as mpg and author with your dvd authoring tool.
    dvd shrink (free) in the reauthoring mode to cut out what you want.
  3. Member scottb721's Avatar
    Oct 2002
    Australia
    Thanks very much
    Feb 2004
    Australia
    mpeg streamclip .
    Dvdshrink , beware , audio issues may appear if you intend on rejoining them later .
  5. Member scottb721's Avatar
    Oct 2002
    Australia
    How so ?
    VideoRedo seems the simplest and I think my process will be as follows.
    Find basic cut points, extract as mpeg, repeat for each DVD, load all mpgs into video editor and fine tune the cuts and transitions and then output mpeg for authoring.
