I need a high quality DVD Burner, the best there is, so there is nearly no loss in quality.
I also need a tool to create credits at the end of my DVD, the kind that scroll down.
Does anyone know where I can get these?
It takes more than just having a high quality DVD BURNER. Using good quality dvd media such as VERBATIM & TAIYO YUDEN is important as well.
If you have a SATA connection on your motherboard I'd suggest getting the SAMSUNG 20x SATA S203B dvd burner. If you don't have SATA connections you can use a PCI SATA CONTROLLER CARD. Or just buy a PATA PIONEER 112 drive.
Check out the SAMSUNG S203B review at Cdfreaks.com. They also have dvd burner forums there as well.
http://www.cdfreaks.com/reviews/Samsung-SH-S203B-DVD-Burner-Review -
To start:
The burner really has nothing to do with picture quality of your DVD's video. It just places the what you create in other applications onto the media. The burner is pretty much a "works or doesn't work" part of the equation. Check out the DVD Writers forum here for plenty of good advice on choosing a model that works best.
As for the software it's a tough question to answer. What are you trying to accomplish? Are you transferring home movies from a camcorder to DVD? Transferring old VHS to DVD? Do you want to want to edit your footage? Most importantly "What is your budget?"
The more specific you can be the more help you'll get. You've come to the right place.
create high quality dvd
By happyjays123 in forum Newbie / General discussionsReplies: 5Last Post: 11th Sep 2011, 22:12 -
high quality .mkv from DVD?
By avextraxjp in forum Newbie / General discussionsReplies: 3Last Post: 8th Mar 2010, 00:28 -
DVD to AVI (high quality)
By bob_smitty in forum Newbie / General discussionsReplies: 1Last Post: 4th Oct 2009, 10:39 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33 -
High Quality DVD vobs to PS3
By The_Lurker in forum DVD RippingReplies: 6Last Post: 14th Oct 2008, 09:49
