    Nov 2006
    United Arab Emirates
    I've been always tried to download this codec but everytime it give me a black screen & disappear quickly..so what's wrong that I can't download the code .. cuz I really need it to convert my movie.
    please I do really need help..
    I guess you have downloaded the x264 encoder and it's a standalone command line encoder, use it together with a gui like megui. Or you can download a vfw codec that you can use in for example virtualdub from http://gabextreme.googlepages.com/x264vfwunited .
    Nov 2006
    I tried to download the codec several times but everytime I download dosen't work on my PC .. I think something wrong maybe that it dosen't work fine with my PC .. I've tried on my friend PC & it works perfectly..
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Is it not downloading or are you not able to run it? There is a big difference.
    Google is your Friend
  5. Member Schmendrick's Avatar
    Feb 2003
    Germany, Northrhine-Westfalia
    @arabian: Like Baldrick wrote x264 from http://x264.nl/ is just an encoder and not a decoder. ffdshow which you can download from the same website contains a avc/h.264-decoder, but this decoder so far is not able to handle all avc/h.264-compression options like paff and cabac. So far from my experience either PowerDVD7-Ultra (Only the "Ultra"-edition) and WinDVD8-Platinum, Elecard (Mainconcept)-h.264-decoder-package and Sonic-Cinemaster come with decent avc/h.264-decoders able to handle all kind of different variants of avc/h.264-clips like from DVB-S2-transmissions, Bluray and HD-DVD.
    Schmendrick
  6. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    The Op mentions "convert my movie", so I believe he is wanting an encoder.
    Aug 2006
    @ arabian,
    Avidemux works well for conversions to x264 and is pretty easy to use. The default settings should work fine. It comes with the x264 encoder built-in. Windows version here:
    http://mulder.dummwiedeutsch.de/home/?page=projects#avidemux
