I think there is a problem with the new version as all my svcds are getting reencoded, PAL(480x576) and NTSC(480x480) file are affected.
According to the change log SVCDs should not be affected
- ADDED: Re-encoding of non compliant mpegs to DVD specs - apart from SVCDs.
				Results 1 to 13 of 13
	here is a log of a PAL svcd.
 I aborted when the encoding started.
 svcd2dvdlog-20070925200457.txt
	ok i have fixed this. can you redownload and confirm? SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
	Excellent - thanks for the headsup! SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
	Hi,
 I have a similar issue.
 My assets are mpg2 compliant. But when trying to author to dvd using svcd2dvd, it will always reencode them to new files with _s2d.mpg extension. This never happens if I use Tmpgenc Dvd Author 1.6 - it will take my mpg files just fine without reencoding.
 Is there a switch or anything I could do to avoid this "re-encode" stage?
 Thanks in advance.
 wm2
	Can you post your log file so i can see what is going on please? SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
	Thanks for the prompt reply.
 When I try to do it the next time, I will capture the log file and post it.
 Later.
	Click HELP -->Logs. Then post the file from this run. Dwight
 "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
 - Herm Albright
 www.martialconcepts.com
	Thanks and here it is... but the file is too big, I have to make it into 2 parts. The first part is attached here and the second part will follow.
 svcd2dvdlog-20071013105249-part-1.txt
	Your files are not being re-encoded, only de/remuxed to be (more) DVD compliant for authoring. Nothing wrong there, that's how it's supposed to work. Dwight
 - Herm Albright
	Forgive me for I still don't understand why it needs to de/remux my files to be (more) DVD compliant. As TDA would take them just fine without issues. Secondly, the quality of the reencoded results are definitely blockier.
 Nonetheless, I appreciate the effort.
 Also, I sincerely wish that you can consider this (a switch to skip re-encode) as a suggestion for future feature.
 Best regards.
  how do I convert Nero recoded filesBy syvart in forum Video ConversionReplies: 2Last Post: 10th Dec 2009, 09:56
  I have SVCD2DVD v2.5.3300.0By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd Nov 2007, 04:57
  2.5.3300 SoundproblemsBy Caesar69 in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 21st Oct 2007, 17:05
  I recoded my VOBs to AVIs, now I have like 'motion lines' thru the video??By lrfowler in forum Newbie / General discussionsReplies: 1Last Post: 8th Oct 2007, 20:43
  Winavi v8 SVCDs jerking with SVCD2DVDBy nawo69 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 13th Jun 2007, 17:02
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
