    Sep 2007
    Hi everyone,
    I have compiled ffmpeg on fedora core 3 with following options as a static library
    ./configure --prefix=/usr --libdir=/usr/lib --mandir=/usr/share/man --enable-libmp3lame
    --enable-libfaac --enable-libogg --enable-libvorbis --enable-libfaad --enable-libxvid --enable-libx264
    --enable-liba52 --enable-liba52bin --enable-libogg --enable-libtheora --enable-libvorbis --enable-pp
    --enable-static --disable-shared --enable-pthreads --enable-libdc1394 --enable-gpl --disable-strip
    --extra-cflags="-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector
    --param=ssp-buffer-size=4 -m32 -march=i386 -mtune=generic -fasynchronous-unwind-tables"
    it runs fine on fedora but when I bring it on to CenTOS its crashing with a floating point error, do we have to start some flags which make it cross linux compatible, appreciate your quick response.
    I think our linux forum is best for this topic. Moving you.
    Apr 2003
    Why are you trying to compile it for fedora core 3 when a compiled version already exist?
    Check out this site pre-compiled rpm packages.
    http://rpm.pbone.net
    Besides Centos is the equivalent for RedHat EL versions.
    Sep 2007
    I am trying to compile because I would need the biinary with x264 as well as 3g2 to flv conversion. Does the binaries already available have these options, how can we test the rpm if they have so and so features.
    Thanks for the response.
