Needless to say, thanks to iriver and the freeware iriverter, I'm a big fan of AVI. What I need to know, for scripting purposes, are the most optimal specs for these devices:
1> Gamepark's GP-32
2> Gamepark's GP-2X
3> Phillips DVP-642 DVD/Divx player
I know on the 642, some of my videos play fine, others play with the top and bottom cut, and others tend to make the player puke. Specific optimal specs I'd like. So far as general specs, I have what you don't want for the Phillips:
1) Packed bitstream.
2) QPel (Quarter pixel)
3) GMC
4) Video bitrates higher than 2000 Kbps
5) Resolutions greater than 720x576
So, please optimals?
MKV: Merely Krappy Video.
Subbers, a request from an avid viewer: Either don't use mkv, or supply avi or mp4 as an alternative.
For those frustrated with converting MKV: http://www.immortalmusic.net/mkv/ -
Try this: https://www.videohelp.com/tools/AVI_ReComp
Works great for fixing avi files that don't playback properly.
As for videos that playback with the screen cut off, check the resolution. It's likely those aren't in a standard resolution (PAL videos output to NTSC TV for instance...or vice versa).Google is your Friend -
Best maximum resolution for 16x9 AVI is 640x352. Anything larger gets squeezed up to full screen. Always had best results with Xvid at 1600-1800kbs and MP3 audio at 224k. -
So far, I found the GP2X can handle 640x480 using the same video/audio encodings of the DVP presented. Baiscally, for Iriverter fans, here you go:
For DVP-642 SD (4:3), and GP2X:
maxVideoBitrate=1800
maxAudioBitrate=224
dimensions=640x480
maxFrameRate=30
wrapperFormat=avi
audioFormat=mp3
For DVP 642 WS (16:9):
maxAudioBitrate=224
dimensions=640x352
maxFrameRate=30
wrapperFormat=avi
audioFormat=mp3
As far as GP2X goes, no trial on 320x240 (another rumored item). Hey, think maybe this should be a sticky?MKV: Merely Krappy Video.
Optimal tracking for video != optimal tracking for audio
By miamicanes in forum RestorationReplies: 4Last Post: 16th Oct 2014, 11:52 -
Can't hear audio on PS3 from AVI (specs included)
By bound4h in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jul 2010, 14:49 -
PS3 won't play audio from AVI (specs included)
By bound4h in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2010, 19:16 -
USB capture devices vs USB tuner devices...... which are better for recording?
By True Colors in forum Video Streaming DownloadingReplies: 1Last Post: 31st Jan 2010, 15:04 -
Please Help! How can I change the audio specs ONLY of an Xvid/AVI ??
By moiz in forum Newbie / General discussionsReplies: 16Last Post: 17th Oct 2008, 14:30
